Hello All!
Not totally new here as I have asked questions before, Got a lot of help and have greately appreciated it!
I am well along on my first project which is actually what got me started with picaxe.
This whole thing started for a friend. He owns several "Hawaiian Shave Ice" concessions and has had a lot of problem with his employees using too much of the flavorings
He had run across an "Instructable" article on a drink mixing machine and thought that it would be easy for me to just use the code provded to make something that would control the amounts dispensed.
I tried to explain to him that I would need to "learn" the picaxe before I could do much and so far it has been quite fun!
I have the program pretty well written,, well at least to where it works with my boards and in VSM. ( I have been using VSM for testing before building boards to save time)
I had a little problem figuring out how to count the different flavors, but finally got it working,, it will count up 10 different mixes. Problem is he has more than that number of flavors with combinations.
Like not only do I have: Lemon, Lime, Strawberry, Bannana, etc, etc, but also: Strawberry/Bannana, Lemon/Lime, etc, etc,
I am using a 40x2 and the way I am counting the mixes, controling the 8 or more solenoids to dispense and having 4 input switches, I have basically run out of pins!
Basically I am looking for ideas on ways to register more choices (flavors) and a way to display them.
Originally I planned on simply using 10 LED's counted from button pushes to display and keep track of the flavor.
In other words,, button pushed 3 times,, Led # 3 is lit, b0 carries the count, goes to flavor number that corresponds with count (b0) and dispenses the correct amount of flavor.
Now I find out I need a minimun of 22 flavors and like I said,, I have run out of pins!
I know you can add another picaxe chip (dont know how to do that yet though) to add more pins for more Led outputs, but with more than 10 leds up in front of the employee it would/could get rather confusing.
I also thought about using an LCD screen
The person who wrote the "Instructable" artcle used a single Nixie tube but he only had 10 drinks and that wont solve my problem plus form what I have read the voltage used for these tubes is rather high and with mostlly teenagers as employees,, who knows what could happen!
Any suggestion or ideas would be greatly appreciated!
If anyone wants to see my code let me know and I will post it.
Thanks in advance
Randy
Thanks in advance
Randy
