first, sorry for my english... it's not my native..
* i just bought picaxe 40x1 (pic16f877 i beleive) along with the 28x/40x project board (AXE022) and as well the serial cable.. well, everything is well soldered already when it reach me.. then i put into the slot picaxe 40x1 to start download the simple program i wrote long time ago into it (and my codes run very well in within the simulation of 28x1 mode in the editor).. (my editor version is 5.1.6)
* now, come my trouble, first i try with the simple testing program (the blinking LED).. i realize it's hard to download to my picaxe.. most of the time, it failed.. in 100 downloads, only 1 to 3 were succeed.. most of the time, it can't detect anything on the line... i've tried to set down the baud of my comm to 2400, 4800 and 9600... but still the same probs.. now i set back up to 9600...
* talking about the successfull download, when it sometimes give me a chance of feeling happy, it first gimme a dialog window saying that my mode is not right, it detect that i have to set to 28x mode only with 4MHz.. the i set it to what it suggested, then download it with a flying colours.. so the test programming running very well... nice, blinking LED with pause 1 sec on every toggle.. then i try to download my program that i wrote into it but it failed to connect so many times like 50 or something with only 1 successfull at the end.. im very frustrated hit f5 over and over again.. then do a few changes and want to download it back into it, it failed to connect again and again... even i tried with everything that i could also the same thing happens.. try to download with the testing program back also failed, even i try to clear the hardware memory also failed... i move from the laptop to my PC now... the same desease happens...
* my question, it come up to my prediction - is that because i used 40x1 on the 28x/40x project board? is that why my successfull download ask me to set to 28x (PIC16f874A) only?? im decided to buy 40x1 cos a lot more function and memory that i really need in my project instead of buying 40x (and as far as i know, 40x superseeded by 40x1 already rite?).. so i can't compile a few codes from my project because of that... which is i comment it out for while to make sure that it can compile succesfully.. then i try with 4.5v batter and 9v battery also the same 'hard to download' problems still remains.. it's more weird, when i compiled (successfull one) and download it into the picaxe, even i disconnect the external 4MHz, it still can run smoothly (which is i beleive internal resonator only appear in x1 chip only rite)... the why my codes still running when i programmed with x mode instead of x1 mode? - means that, the benefit of picaxe 887 is still can be accesed with no problem rite? so why do i have to set it to 28x mode instead and narrow down the capabilities of x1??? and is state my firmware is 7.8 for 28x and firmware 8.0 for 28x1 in bracket? but the most important thing to settle down is, how to download with just only once 'magic finger'.. is that normal that at all time u guys download, its only 30 percent of success?
