Hello again!
I've got a mini project on the go, where I am trying to use a 20X2 to drive some 7 segment displays from i2c input, but I am getting "ghost digits".
For simplicity of the code on the 20X2 during testing, the bytes received contain the data for the 7 segment abcdefg LEDs and not actual numbers.
I am using outpinsC (0,1,2,3,4,5,7) (6 is input only) for the abcdefg outputs, and outpinsB (0,1) for the common of the displays. (if/when I get this working, I'll add more digits).
I think the crux of my problem is that I need to set outpinsB and outpinsC at the same time but the only thing I can do is set them sequentially.
The i2c receive and interrupt are working as expected, and the correct digits are clearly visible, but the "ghost digits" from the multiplexing are causing me problems.
ghost digits: a fainter version of the another digit is visible on top of the desired digit.
Using another IC, such as a BCD to 7 segment decoder still has issues because I'd need 4 pins for the BCD, and that only leaves 2 or 3 pins for the multiplexing (2 used from B for i2c, and C.6 is input only). So if I want to run more than 3 digits (I do) I will have the same issue of trying to set B and C simultaneously.
Is there some way to set outpinsB and outpinsC at the same time?
Failing that, is there some other strategy to minimise the impact of the sequential outpins assignments?
Thanks
ps. I know there are modules available which do exactly what I want, but where is the fun in that?
init:
let dirsB = %00001111
let dirsC = %11111111
hi2csetup i2cslave, %10100000
setintflags %01000000,%01000000 'set up i2c interrupt
'digit #1
let outpinsC = b1
let outpinsB = %00000010
pause 5
'digit #2
let outpinsC = b0
let outpinsB = %00000001
pause 5
interrupt:
hi2cflag = 0 'reset flag
'get digits from scratch
get 0,b0
get 1,b1
setintflags %01000000,%01000000 'reset i2c interrupt
Thanks
