I’m looking into parallel processing using two PICAXE 28X1, with one as Master and the other as Slave. Both have serial download cable ports and it’s a pain switching from one port to the other to reprogram Master or Slave. I was thinking of doing something like this:
Pins 14 and 15 are on an I2C bus. Slave pin 28 goes to Master input pin 18. Reset goes to pin 1 on both Master and Slave. Serial in pin 6 goes to Master and Slave, as well as serial out pin 7.
Both Master and Slave are disconnected. With a menu system, the idea is to select an option to reprogram chips, with options to reconnect either the Master or the Slave to the download cable.
I haven’t tried to download yet, because serial out using SERTXD on Master or Slave doesn’t work. There’s nothing coming out. I’m guessing there’s something wrong with the circuit between pins 6 and 7 on Master and Slave.
