jensmith25
Hi all,
I have another project I'm working on for a customer. He has an O gauge model railway and wants to light up the carriages when motion is detected. He previously bought a little motion detection microprocessor which is designed to run off a 3v coin cell but it's designed for N & OO Gauge and isn't powerful enough for the extra LEDs required to light up an O gauge scale carriage. (One goes in each carriage with a 3v LED strip). I provided a longer LED strip with extra LEDs but the carriage is barely lit using the microprocessor while being very bright when lit directly off 3v (2 x AAA's) so there must be a lot of resistance in their circuit.
Anyway, that is the background.
I have established that I can power the 3v LED strip with 9 LEDs with the tiny AXE231 via a FET but what I need is the best way to detect the motion of the train. The idea being that when the train moves the lights come on and then switch off after it stops. There would be one in each carriage and he wants to do this rather than wire the carriages together.
I know you can use an IR receiver and transmitter but this seems more suited to performing actions like turning on signals etc rather than keeping lights on.
After extensive searching on the forum and Google I found a reference to a vibration sensor SEN015
http://www.picaxestore.com/index.php/en_gb/electronic-components/switches/sen015.html
and wanted to check if this will do what I need or if there's a better way of doing it. There's no data sheet or much info on the page as to how it works!
EDIT: - I've also found this one as an alternative which says it's for use with moving objects like bike lights etc. Not sure if it would be better or if they do the same thing: http://www.rapidonline.com/electronic-components/sensolute-micro-vibration-sensor-omnidirectional-178104
Thanks for your help.
Jennifer,
Jennifer,
