I have built a PWM drive with a 555 and an op amp. The output from the op amp drives a trans which drives an n channel mosfet.
I have the emitter of the trans oscillating, so the pwm is working and I can see the duty cycle changing as I tweak a pot.
But the motor isn't changing speed.
I removed the trans from the circuit and the motor still went. ie the motor is being driven by the supply into the drain and the source connected to gnd ie the mosfet is shorted.
So I am assuming my mosfet is toast? But I have a replacement and it behaves the same way.
How can I test them? It must be a faulty mosfet or am I missing something? It is possible I fried them when trying to build an H bridge a while back.
