Hi all,
I'm after a bit of help.
I'm working on a circuit that generates a pwm signal that feeds into a transistorised AND gate to an emmitter.
I also need it doing a couple of other tings at the same time when a button is pressed (increment a counter, trigger two pins high/low and generate a 2nd PWM signal that also feeds through the AND gate to the emitter.
I've got the whole shebang working using a 14m2, two transistors plus switch. what I'm wondering is, is there a way to build the AND gate function of the two transistors into the Picaxe?
I can get it working as an AND gate, but can't get it doing anything else at the moment.
In all honesty, given the difference to the overall circuit is two transistors it's not crucial if It's not possible, but this is more for a refinement to the circuit....
Thanks all
Thanks all
