Roboteernat
2 questions really. the first is to do with my code, second is programming errors.
1.
i have modified 2 servo motors so that they drive continuasly and are speed controlled by the pwm value. in the ocde, i wish that at a point they stop driving, however they seem to stop and continue to drive. does anyone know what value is used to stop a modified servo?
or would i need to attaach servo to another command, such as...
servo1. .----|. . . .|----servo command pin
. . . . . . . . . .|.AND|----o/p pin to activate drive
servo2. .----|. . . .|----servo command pin
ie using 2 and gates to turn them on/off etc??
im sure i have worded the question ina way no one understands so i will clarify if needed.
2. i dl the new program editor onto my laptop, and everytime i open the options pane and close it, or start a new program window, i got an error message.
"failed to open reserved words file"
anyone know what this means, it programs me chips well so...
also i read a message anbout changing the setting to enhanced on the options > editor menu. however this doesnt work for me, and comes up with lots of errors.
im going to try and reload the programming editor so maybe this will fix??
thanks.
nat
Edited by - Roboteernat on 18/02/2007 11:17:37
Edited by - roboteernat on 18/02/2007 11:18:30
Edited by - roboteernat on 18/02/2007 11:19:06
1.
thanks.
nat
