My main PC is a 3Ghz machine running XP service Pack 3. I had previously used it to program Picaxes via a AXE027 USB cable working on Com Port 4. (The USB connection is from a USB port on the motherboard via extension board fitted at the front of the PC providing 4 USB ports). All the USB ports appear to be working correctly.
I last used the PC to program Picaxes around 2 months ago. Yesterday I connected the PC
up to a breadboard layout that I know is working. However the PC did not recognise that a AXE027 cable was present. When I checked I found that the Device Manager only lists COM Port 1, no others are present. The Picaxe Programming Manager shows (via Options - Serial Port that Com Port 1 is in use and all other ports are "Not Available", although it shows the AXE027 is present on Com Port 4.
I have not been able to rectify the problem.
Qn 1/. What caused my Com Port 4 to dissapear?
Qn 2/. HOw do I rectify the situation?
Clockwork
Clockwork
