nitrous2000
Hi guys,
I am trying to design a project that will read one of 6 NO switches to detect the position of a six sided cube. So, if the die face is showing a 4, a switch will close to indicate this. I have a 4-direction tilt switch and would add a couple of single direction tilt switches in a back-to-back configuration.
I wondered about using a PIC with 6 I/O, one for each switch. This would result in a data signal being sent to a transmitter which would be received some distance away to finalize the project.
What is the smallest PICAXE chip I could use for this application? Can I get away with a simple 08M2? I should say, space is at a premium: I'd like to stick this in a cube less than 3/4" across.
Thanks
Doug
Thanks
Doug
