frankilische
Please i am trying to see if i could save data from a sensor network into a MICRO-SD card. i am actually using the picaxe connnect (AXE210) board and would need suggestions on how to get this done. basically i am trying to see if i could rule out the use of a computer connected to the coordinatior node and i hence assume that the coordinator which receives data from the other terminal nodes does not need the MAX 3232 chip but rather a picaxe chip since there is no computer connected to it. I hope i am right on that. Any suggestions on how to get this done would be appreciated. The big picture is having a sensor network with its coordinator node connected to a Micro-sd card where it can save data to be used later on instead of having a computer on all the time.
