If I plug my breadboard with only an 08M on it, via a serial to USB adapter into my laptop which is running editor ver. 5.1.3 and download a simple program all is well. If I plug the same board, same adapter and same power supply into my desktop now running ver. 5.3.3 all I can get is Memory verification failed (at around 240 bytes usually but it varies).
On the desktop I have tried:
1. An AXE027 but I could never get it to work even though it was tested as OK by the supplier and I downloaded and reinstalled the driver several times
2. Four new chips
3. Different USB ports
4. Updating the editor
5. Reinstalling the adapter software
The firmware verification works OK but I can't even clear the memory. So if it's not the chips, the breadboard, the adapter, the power supply, the adapter software or the USB port what could it be?
2. Four new chips
