More capacitance in a DC power supply circuit more fully stabilizes the circuit voltage. It won't affect the actual voltage of the circuit. An electrolytic capacitor acts like a small reservoir of charge, but it won't charge up to more voltage than it is supplied. NOTE: Electrolytics must be placed with correct polarity or they will most likely fail in a possibly loud and messy way.
The rule of thumb for the small value capacitors (100n) is to place one across the power rails very close to each IC it filters, not use a bulk one for all the IC's. They need to be close to each IC to do their job well.
The bulk electrolytic capacitor (200 to 330 mfd or so for three chips) can simply be one cap of three times the nominal value used with one chip. Place it near the regulator. If the actual power supply is more than a couple of feet from the bd, then an additional couple hundred mfd cap and another 100nF cap should be placed on the input to the 7805 as well. Note that the capacitors on the high voltage side of the regulator should have voltage ratings at least 30% above the voltage they will operate at.
Aluminum electrolytic capacitors work well, but tantalum electrolytic caps work especially well. I use either, but if I have one of each handy I will install the tant..
Those are rough rules of thumb used for reliable capacitor filtration of circuit bd power rails and IC's throughout the electronics industry.
If you've already fabricated the bd, then just add the capacitors on the bottom to test the result. If the bds haven't been fabricated yet, run the test, then add the caps to the design. Either way, a solid design needs those caps.
