;******Konstanter *****************************************
symbol trykket = 1 ;trykkbryteren er p? input 3
;PWM-konstanter===========================================
symbol fclock = 16000 ;Klokkefreq i kHz
symbol T1s0 = fclock/4
symbol T0s5 = T1s0/2
symbol T0s2 = T1s0/5
symbol T0s1 = T1s0/10
symbol T0s05 = T1s0/20
;Lager pwm-konstanter med utg.pkt i klokkefrekvensen
symbol fpwm = 100 ;pwm frekv kHz
symbol pwmtemp1 = fclock/fpwm ;kladd
symbol pwmtemp2 = pwmtemp1/4 ;kladd
symbol pwmperiod = pwmtemp2-1
symbol DCinc = 10
;Verdier for ulike dutycycle prosenter
symbol DC05 = pwmperiod/5 ;5% DC
symbol DC15 = DC05*3 ;....
symbol DC25 = pwmperiod
symbol DC50 = pwmperiod*2
symbol DC75 = pwmperiod*3
symbol DC100 = pwmperiod*4
symbol DCstart = DC05*8 ;Startverdi v/testing, litt mindre enn
;forventet testverdi. Finnes v/testing
symbol DCmax = DC75 ;DC = 515<->100% med fpwm=60
;For strom/spenningsberegninger
symbol calibvmax = 262 ;Svarer til VB=4,0V, nedre batt grense
symbol adc10max = 1023
symbol VBmin100 = 400 ;Min brukbar VB
symbol Vcal1064 = 65535 ;Intern refsp.x64000 for beregn av VB100
symbol Vcal100 = 102 ;Intern refsp.x100 for beregn av V og I
symbol Vcal1000 = 1024 ;Intern refsp.x1000 for beregn av V og I
symbol Rmverdi = 200 ;Motstanden som brukes til Iomaling, ohm
symbol Rm4del = Rmverdi/4 ;Forenkler beregninger
symbol Io10settv = 500 ;5 mA i 2kohm dvs 50 mW , gir VRm100=100
;***********[ Variabler ]*********************************************
symbol Flagg = b0 ;Flaggene, ingen saa langt
SYMBOL temp1 = b1 ;Gen word variabel
SYMBOL tempwl = b2 ;Low byte av tempw1
SYMBOL tempwh = b3 ;Hi byte av tempw1
SYMBOL tempw = w1 ;Gen word variabel
symbol DC = b4 ;Dutycycle for pwm
symbol DCtest = b5 ;Dutycycle for pwm
symbol teller = b6
symbol Io10 = b7 ;Beregnet DUT-str?m i mA x10
symbol tempw2 = w12
symbol calibval = w8 ;for calibadc, ref = 1,024V
symbol VB100 = w9 ;Ny beregnet batt-spenning i volt x100
symbol Vo100 = w10 ;Utspenning ref til 0V x100
;VB100=400/450 -> VR100=199/202 @25^C
symbol Vz100 = w11 ;Beregnet DUT-spenning i volt x100
;******I/O definisjoner **********************************************
SYMBOL Red = c.0 ;
symbol gul = c.1 ;
symbol VRmpin = c.1 ;Pin koplet til VR for beregn av Io
SYMBOL Green = c.2 ;
SYMBOL pwmpin = c.2 ;Output pin for pwm
symbol tone = c.2 ;pinnr. for lydgiveren
symbol Bryter = pinc.3 ;Inp for AV/P? via wakeup/sleep
SYMBOL Ref100 = c.4 ;
symbol pinc4 = c.4 ;pinnr. for potmetret
#picaxe 08M2LE
#terminal 19200
Init:
setfreq m16
temp1=pwmperiod
low pwmpin
DC = DCstart ;starter litt lavere enn v/test
pwmout pwmpin,pwmperiod,DC
pause T0s5 ;Gi 0,5 s til stab....
hoved:
Vz100=3;For testing ZZZZZZZZZZZZZZ
hovedlp:
DC=DC+1
pwmduty pwmpin,DC
readadc10 VRmpin,tempw
'sertxd (#tempw,"-");For testing ZZZZZZZZ
gosub FinnV100
sertxd (#tempw,13,10);For testing ZZZZZZZZ
Io10= tempw/2 ;=VRm100/Rm*100 for mA der Rm=200
loop until Io10>=Io10settv or DC>DCmax
if DC>DCmax then gosub Error;Tester battsp.!
DCtest=DC ;test-verdi spares
pwmduty pwmpin,DC25 ;For å redusere spenning på utgangen
'gosub VentPaaTrykk;For testing ZZZZZZZZZZZ
goto hoved;For testing ZZZZZZZZZZ
;Det er klart til testing
high red ;klarsignal til bruker
;Venter paa at DUT plasseres mot kontaktene
readadc pinc4,temp1
loop until temp1>5 ;(>0)Venter paa DUT
;DUT plassert, vent litt, og videre!
pause T0s1 ;100ms vent
pwmduty pwmpin,DCtest ;Ca 50mW ut
;Venter paa at DUT fjernes. Naa maa Vz maales
tempw2=tempw
pause T0s05
readadc10 pinc4,tempw
loop until temp1<2 ;
;DUT fjernet
gosub VentPaaTrykk
goto hoved
bit3=c.1 ;Snu c.1 inn for m?ling av LED sp. VLED
goto hoved
FinnV100: ;Kalles med avlest adc10-verdi i tempw
'tempw= 3'For testing ZZZZZZZZZZZZ
tempw2=1
do ;Finner narmeste 2**N > tempw
tempw2=tempw2*2
loop until tempw2>tempw
tempw2=32768/tempw2*2 max 1024 ;Naa er tempw2=1024/k
temp1=1024/tempw2 ;og temp1 er naa = k
calibadc10 calibval
calibval=237 'for testing,tilsv. VB= ca 4,4V ZZZZ
tempw = tempw2*tempw/calibval*temp1/10
return ;tempw = V100, dvs maalt spenningx100 (10mV)
Error:
low pwmpin
toggle red
pause T0s2
goto Error
VentPaaTrykk:;Venter p? at bryter strykkes til den slippes *******
loop until bryter=1
pause T0s05
loop until bryter=0
HVIL: ; Hvilemodus for ekstremt lav batteristrom
pwmout c.2,off
low c.0,1
disablebod ; Sl? av str?mforbruk!
nap 200 ; "Sov" i 0,3 sekunder
enablebod ; Sl? p? str?mforbruket igjen
loop until bryter=1 ; Hvis det er blitt trykket, start opp!
high red ;Vaakn opp!
goto Init
