Here's a code fragment I use for monitoring the supply voltage:
The ADCON0 stuff is because I originally used this in a low power circuit, it isn't needed unless you want to obsess about the power.
The battery voltage can be used to prompt the user to replace the batteries.
Chris
symbol ADCON0 = $1f
readBattery:
; enable the ADC
peek ADCON0, b2
b2 = b2 or 1 ; set bit 0 to enable the ADC
poke ADCON0, b2
; get the supply voltage by reading the 1.024V
; adc calibration voltage using the supply voltage
; as the DAC reference.
calibadc10 w0
; disable the ADC to save power
peek ADCON0, b2
b2 = b2 and $FE ; clear bit 0 to disable the ADC
poke ADCON0, b2
; convert to 1/10V
; calib adc is 1.024V
; V = 1.024 * 10 * 1024/adc
w0 = 10486/w0 ; voltage in 1/10 V in low byte
battery = b0
Chris
