I have re-read the data sheet on the CHI035 board numerous times and have been unable to find a max allowable voltage for the output side of the FET board. The data sheet suggests 12 volts in the example at 1 amp, but I would like to use 24 volts at 1 amp for a project I am working on. Otherwise would it be better to link the standard power project board to a stepper driver board and call it good. I really like the abiliy to cut the resistor off and seperate the input voltage from the output voltage all on one board since additional boards and additional wiring connections tend to create issues with durability and noise in the system. TIA for your thoughts on this issue.
Bob
Bob
