Z zeljko.ciric New Member Sep 27, 2010 #1 I try find (without success) how to conect MAX6956 and (2) ULN2803 to control 16 relays. Is that even possible?
B BeanieBots Moderator Sep 27, 2010 #2 http://datasheets.maxim-ic.com/en/ds/MAX6956.pdf Each port is individually user configurable to either a logic input, logic output, or common-anode (CA) LED constant-current segment driver. Click to expand... Data sheet says it's possible With 28 possible outputs, that should be enough to drive your 16 inputs. Simply configure for LOGIC output and connect to ULN2803 input.
