Before update I have PE 5.4.2 and problem was this:
If in code was command 'eeprom' and press 'Program', PE gives message: 'Data eeprom Memory location already used!'
If I removed lines eeprom, it go fine, but it says ~1710 memory used, syntax check say ~2044 bytes used.
Now I downloaded update 5.5.0:
I can't program chip any more because it give me a message 'Data eeprom Memory location already used!', even in code doesn't include command 'eeprom'!
Syntax check give message 2048 bytes used. (Code is the same that before update!)
What's wrong?
What's wrong?
