I am working on a 40X2 project where I am trying to use the least possible power. I have found the hibernate command which seems ideal for what I want, as it uses very little power when it isn't running and is only awoken when an external stimulus is applied. However, it doesn't seem that this is possible with the 40X2 ? If this is the case, could you advise if there is a similar or equivalent command for the X2, or at least which is the lowest power mode the X2 will support.
Many Thanks.
Many Thanks.
