Hi Technical,
I'm keen to reduce the power consumption of 08Ms in Sleep mode, (for battery powered RF jobs).
The lowest I can reduce current consumption in Sleep is 0.65mA using a low current LM2936 regulator and have followed the advice of previous posts - such as pulling unused 08M inputs to ground etc.
Is there an update to the 08M firmware as mentioned below?
Technical Posted - 14 November 2005 15:5 Further research has shown that the 12F683 (used for the 08M) has a unique brownout option (not found on any other chip) that we were not previously aware of - a fuse setting that enables the BOD during normal use but automatically disables it during the sleep command. This would overcome this sleep current issue on 08M chips (not available to 08 chips).
We will do some tests and if this operates as expected we will implement this in a new release firmware update early in 2006. However this will a 'new' feature not available on existing chips.
________
________
