longer delays
This will pause for about an hour ...
- FOR w0 = 1 TO 60 ' 60 minutes
- PAUSE 60000 ' 60s
- NEXT
Edited by - hippy on 11/05/2006 03:56:27
Rickharris
<code><pre><font size=2 face='Courier'>
start:
pause 1000 ' adjust for accuracy
B0=B0+1
if B0=60 then min
goto start
min:
b0=0
B1=B1+1
if B1=60 then hr
goto start
hr:
B0=0
B1=0
B2=B2+1
if B2=13 then reset
goto start
reset:
B2=0
goto start
</font></pre></code>
B0 holds seconds
B1 holds mins
B2 holds hours
Pick out what you need
Jeremy Leach
<b> Approximate </b> 12 hour delay, unless you're running the PICAXE from a crystal.
For instance if the internal clock is running 92% of 4MHz then the delay will be 13 hours not 12.
Even a crystal-driven PICAXE won't give exactly the right delay because of the miniscule delays in processing the commands. There's over 2000 command steps executed in your loop so this will have a small effect.
Edited by - jeremy leach on 12/05/2006 08:36:33
