BrotherJoe
I've hit a bit of a clue wall and need a nudge. This is a bit more of an electronics question than a PicAxe question, but, it relates..
I've been working on a directional wattmeter to interface with a picaxe.
Initially the circuit was designed to drive analog movements and give forward/reflected *relative* readings.
I thought it'd be far more useful to make something and use the power of the picaxe's ADC to derive actual wattage.
Initially my plan was to scale my input voltage (after my RF detector) by limiting my coupling; but, I'd still have a limited range of input power that I could detect and derive.
Enter the Logarithmic Amp. I know there are specialized IC's to do this (AD8307 and 8310)...but I'm compelled to learn, and compelled to bang my head against this by making one out of discrete components. Additionally this will end up as a
I've started out by modeling a simple LogAmp using an op-amp with non-inverting input to ground, and a single supply. Output and Inverting input are tied with a diode, and I'm feeding my signal in through a 100k resistor.
The problem is; I'm having a hard time wrapping my head around what makes it go, mostly because I can't seem to make it go in SwitcherCAD.
My understanding is that I'll feed it some voltage (most RSSI IC's seem to go from some small V to 2.5V or so) and I'll get the log of that on the output.
Dr Acula initiated this with his excellent op-amp tutorial, so, maybe somebody can discuss the LogAmp as well and give me a hand? I feel like I need to see it work before I can start working on the ADC handling code on the PicAXE.
Thanks,
Joe
Thanks,
Joe
