Andrei Reaboi
Hi.
I need to be able to connect a load cell (inline rod end type) small one as well, may be 0-10Lb to PICAXE08M and read the voltage values.
I know that load cells have small voltage ref and they need amplifying.
Is there a way of doing it any other way?
Also, are there any alternative devices that can be connected to picaxe which would monitor applied pressure?
Thank you.
Thank you.
