Andrew Cowan
Apologies for the non-PICAXE question.
I've got a LM2575-12 switching regulator stepping down from 24v to 12v.
I've followed the example circuit exactly, and it worked fine with a previous 12v camera. However, I've upgraded the camera, and come across a problem.
Background:
The camera runs of 12v, and draws 200mA when idle, and up to 500mA when zooming and focussing. The regulator is good for up to 1A continuous.
Situation:
When connected to the camera, the regulator enters current overload mode, where it stays until the load is removed (as per the datasheet).
Looking with my multimeter, the maximum current is 40mA. However, when I use Peak Mode (cutting the detection time to 250uS), inrush current of about 6A is seen (which is causing the regulator to shut off).
So, how do I stop the camera's high inrush current at power-up? I would imagine it has lots of capacitors in it, which charge up when powered. I am doing this for a deadline, so can only use components I have or Maplin sell.
Options:
- Thermistor. However, I doubt the 200mA current it usually draws is enough to heat it significantly to get the resistance down.
- Resistor. I don't mind a small voltage drop - maybe a one or two ohm resistor would help?
Any other ideas? I somehow need to stop this inrush current spike.
Thanks for any ideas!
Andrew
Background:
Situation:
Options:
Andrew
