Hi all, OK I got a gear indicator working fine , but am using a cmos 4011 to block out the constant voltage coming from the hall sensor. What I want to do now is remove the 4011 and go straight from the hall sensor to the 08m2. The program works by reading whether pin c.1 or pin c.2 are high.
As stated the hall sensor continually pumps out around 2.5v so pin c.1 and pinc.2 would allways be high. Then when a magnet comes near it pumps out the 5v going into it.
So I am open to suggestions as to go about eliminating the 2.5v. I was thinking about a voltage divider to drop the voltage below what the pin deems as high but if that does not work then some other ideas would be welcomed.
I want to make this as small as possible and with the 4011 in the circuit it's just to large, I am limited with room on the bike.
Thanks AJ
Thanks AJ
