I have tried programming a very simple program several times. The program is as follows...
No matter what I put in after
the syntax check says there is an error. Simply says pinC.2 = High/Low or whatever registers an error. No idea why this is. I first noticed it while trying to create a if/then statement and ever since LINAxepad says every code is a syntax error. Why? Even this doesn't work...
Either LINAxepad is broken, I'm retarded, or something else is going on. Any suggestions/help is greatly appreciated.
**Note** I've even changed
to just C.2 (which worked for the Hello World blinky program) but now nothing works.
**Note** It is also worth mentioning that the specifics of the program are not of great concern, the concern is that absolutely no code will work.
EDIT:
I tried fiddling around with it and used the PWM Wizard to try to get something to work. And it has, however, anything other then the Wizard generated code will not register successfully.
Main:
pinC.2 High
Pause 500
pinC.2 Low
Pause 500
pinC.2 High
Pause 1000
pinC.2 Low
Pause 1000
pinC.2 High
Pause 1500
pinC.2 Low
Pause 1500
GoTo Main
End
Main:
pinC.2
EDIT:
