I'm at the brainstorming stage of a new project, contemplating how to drive my output. The output is an led matrix (array?) 16 x 10, 30mA per led, so probably driven thru 2803's. My problem is the persistence of the led's, and how often to update the display. Basically the program would be "do a bunch of stuff" "update the matrix" "repeat". The picaxe will be a 40Xx and could use a slave picaxe for output.
The way I see the options:
1) Parallel interface using 26 output pins (16 for rows, 10 for columns). PRO, low chip count, lengthy but easy program. CON, ties up a lot of ports on a big picaxe.
2) Modified parallel using 6 outputs to a 4-line to 16-line decoder (rows) and another 4 outputs to a Johnson decade counter (columns). PRO moderate chip count, moderate program. CON long wait between updates.
3) Serial to a MAX6957, using an output off it to increment a Johnson counter for the rows. PRO moderate chip count, familiarity with serial output. CON really long wait between updates.
4) Using either option 2 or 3 while writing the data row by row into flip-flops, updating the matrix through hardware. PRO no worry about the display update. CON high chip count, providing a clock signal to the output.
Are there any easier options I'm missing? Anyone have thoughts on working with a matrix?
