I just need someone to do a quick sanity check of a thought I came up with tired last night.
Picaxe 18M2 or a 20X2. Both will run between 1.9V and 5.5V and so will run off a 240mAH 3.7 Volt Li-pol battery. However even running at 3.3V or lower, their digital outputs will still run at 5V and supply up to 20mA.
Correct so far?
Okay if the above is correct I have a LCD that requires 5.5V and draws 3mA for its Logic. I think some of you will be able to guess where this is going.
Could I use one of the digital outputs of the Picaxe to power the LCD? Would that work correctly and display correctly? I'm aware that the backlight would draw far too much current for that to work, but in situations where the backlight is not required, i'm hoping this might work.
Thanks all.
Datasheet for the LCD in question:
http://www.bonafide.com.hk/catalog/MC1602-18.pdf
Correct so far?
Thanks all.
