LCD Malfunction
I have a 16x2 lcd connected to the revolution firmware chip, at power on, the lcd displays the "Serial LCD/Revolution c1998" then the screen fills with small triangles.
Any ideas?
I expect it's pickup noise on the input. Try tying that to +V or 0V via a 10K resistor and see if the triangles stop appearing.
tarzan
FRM010
If we are talking about the FRM010.
There is an error in the documentation.
Jumper 3 When closed the serial protocol is inverted, for direct connection to a PC.
I believe that it should read:
Jumper 3 When open the serial protocol is inverted, for direct connection to a PC.
Use N when jumper3 is closed.
Use T when jumper3 is open.
Someone correct me if I'm confused.
