I've been away from picaxe for several years and have just had the need to program another 14m2 with one of my working programs using a standard LCD in 4 bit mode. The LCD refused to initialize using code that I've used plenty of times before, in fact I reprogrammed a working temperature monitor with the original code and it refused to work. My picaxe editor has updated to 6.1.0.0 and I'm not sure what version the original code was written on. The chips program ok with no errors, but I now have a non working temperature monitor loaded with the exact same code as it was initially. Has PE 6.1.0.0 changed? I don't get any syntax errors.
The code below is the same initializing code I have used in several LCD projects with no problem until now.
I've programed the chip to flash a couple of leds which works with no problem.
Mike
Mike
