chopperwalker
Searched all the net and this forum so sorry if it's a repeat...
I came across a brand new LCD 117 kit from a friend who uses arduino. Before starting assembly I did a lot of reading realizing the baud rate issue (this kit runs at a fixed 9600). I have an 18X which I understand I can use setfrq to get to that speed. However, I read on another forum that there is a start bit issue which results in jumbled characters on the screen. Does anyone have any insight on the potential problems here? Can I simply overclock or will I have the same serial communication error?
Thanks,
Chopper
P.S. I noticed that on Anderson's site that you can order preprogrammed 16fs to controll these. Anyone know if the pic could simply be swapped with one that runs at 2400 (like in the 118 kit)?
Thanks,
Chopper
