fastgrandad
I apologise if this has been noted from a previous post but I'm struggling with a code issue that uses this feature.
I'm configuring the hardware latch in an 18M2 so that a positive pulse on SRl sets the latch (SRQ high), then the following code changes so that the next pulse resets SRQ low. Effectively a preset flipflop using SRl as a clock input. It works in hardware but not in the simulator as it doesn't appear to read the SRQ pin. Its only a problem as I'm trying to use the simulator to track down a problem with the total program and I can't!
As I'm new to picaxe, which I'm thoroughly enjoying, I don't know whether there is a time scale where issues like these get addressed.
thanks
Paul
thanks
Paul
