OK. I have looked at most of the data and am somewhat confused. It looks like the smallest Picaxe I can use seems to be the 20X2. But I have not explained my needs. So here goes. The project will need 8 controllers with a minimum of 8 outputs each. However and this is what throws the wrench into to works I also want to make then all I2C slaves with a 40X2 as the master. So am I correct in my assumption or can I use smaller ones. Also I am not real familiar with the I2C bus and am wandering if what I propose is even possible. I have chosen the 40X2 because I may need to expand it some. I will need 8 outputs from the 40X2 but may need more in the future.
Thanks in advance.
Steve
Thanks in advance.
Steve
