Tim Vukman
I have basically lifted the code below from http://www.rev-ed.co.uk/docs/chi008.pdf and I am trying to scan a 4x4 keypad. In the "scan" section, only the last key_value routine seems to work.
For example, as is, only the key_value = 12 routine works. If I comment out the key_value = 12 section, then the key_value = 8 routine is the only one that works.
The keypad is wired such that the rows each have a 10k resistor to ground. The input pins connect on the keyboard side of these same resistors. The rows each have an output port of their own.
The source code is below. I would really appreciate any ideas on how to have all 4 of the key_value blocks active at the same time so that I can just retrieve the key number for the key pressed and move on.
CODE
'keypad interface routine
'picaxe 28x clock project
symbol key_value = b1
'captures the key number pressed
scan:
'set outputs high in sequential order
key_value = 0
'starting point for row0
pins = %00000001
'set to high to provide voltage to keypad row3
gosub key_test
'test the input pins for which column the key is in
key_value = 4
'starting point for row1
pins = %00000010
'set to high to provide voltage to keypad row2
gosub key_test
key_value = 8
pins = %00000100
'set to high to provide voltage to keypad row1
gosub key_test
key_value = 12
pins = %00001000
'set to high to provide voltage to keypad row0
gosub key_test
debug
'watch key number in b1
goto scan
'keep repeating the scan module
key_test:
if pin1 = 1 then add1
'to input pin for row3 (highest) leg 12
if pin5 = 1 then add2
'to input for row2 leg 16
if pin6 = 1 then add3
'to input for row1 leg 17
if pin7 = 1 then add4
'to input for row0 (lowest) leg 18
return 'close the gosub in "SCAN" module
add4: key_value = key_value + 1
'id keys 13, 14, 15, 16
add3: key_value = key_value + 1
'id keys 9, 10, 11, 12
add2: key_value = key_value + 1
'id keys 5, 6, 7, 8
add1: key_value = key_value + 1
'id keys 1, 2, 3, 4
'won't run without this one
CODE
scan:
key_value = 0
pins = %00000001
gosub key_test
key_value = 4
pins = %00000010
gosub key_test
key_value = 8
pins = %00000100
gosub key_test
key_value = 12
pins = %00001000
gosub key_test
debug
goto scan
key_test:
'id keys 5, 6, 7, 8
'id keys 1, 2, 3, 4
