Hello!
I've run into a problem with a 4x5 matrix on a 40X2 I've built. I'm pulling the four columns high one at a time and reading the value of each of the five rows into a ptr. My problem is that every button works fine, but if I push two buttons on the same row, the voltage drops from 5v to .8v and turns off everything on that row. What can I do to fix this? I'm a little foggy on where the sink is. Is it because the output isn't strong enough, or is it in how the inputs are on the silicon? Can I use diodes somehow, or would it be better to use sink detection instead with pullups? Is it a simple programming change I can make? Thanks in advance. Here's the relative code snippet.
EDIT: I have a 10k pull down on each input if that makes a difference.
'Set symbols for button rows and columns
Symbol Col1 = A.0 <These are set high one at a time
Symbol Col2 = A.1
Symbol Col3 = A.2
Symbol Col4 = A.3
Symbol Row1 = pinA.5 <These are read as inputs one at a time.
Symbol Row2 = pinA.6
Symbol Row3 = pinA.7
Symbol Row4 = pinC.0
Symbol Row5 = pinC.1
ReadButtons:
'Read the current state of each button into scratchpad byes 1-20.
'Compare them to previous values in 21-30.
'If they are different determine note on or off, and store cv in pv.
ptr = 1
high col1
@ptrinc = row1
@ptrinc = row2
@ptrinc = row3
@ptrinc = row4
@ptrinc = row5
low col1
high col2
@ptrinc = row1
@ptrinc = row2
@ptrinc = row3
@ptrinc = row4
@ptrinc = row5
low col2
high col3
@ptrinc = row1
@ptrinc = row2
@ptrinc = row3
@ptrinc = row4
@ptrinc = row5
low col3
high col4
@ptrinc = row1
@ptrinc = row2
@ptrinc = row3
@ptrinc = row4
@ptrinc = row5
low col4
-SNIP-
