Hello friends! I want to buy picaxe microcontrollers to do a lot of projects I have in mind. But there is a problem that I cannot find a solution to on the WWW or datasheets/manuals or YouTube etc. The problem is I cannot get a definitive answer to a question I have. Why do all kits and chips use an audio jack, i think 3.5mm or so? I am not unfamiliar to serial connections, USB, etc. I have an FTDI FT232R chip I want to use to convert to USB/Serial. I found a guy on youtube who used FTDI chip and Hex inverter to get the signals on the same page.
If all you need is the right sequencing on data and the Tx/Rx/GND then why use a part that is not something i have or plan on using? Can I ditch the audio jack and just use the hex inverter/ft232r?
Thank you all!
Thank you all!
