Unfortunately home improvements have kept me from making any forward progress on my electronics projects. I'd like to come back to this topic though because ultimately this is where I'd really like the direction of my project to go.
A bit of background:
I’ve been working on a PIR/Counter circuit which works well and I’ve finally released it into the wild to do its duty. Basically it detects motion and the HI from the PIR increments a counter (found
HERE). I’ve also added a reset button.
For now I’ve omitted the 08M chip and just ran the counter directly from the PIR. Reason being is because I wanted to field test the PIR for reliability without adding any unnecessary complexity to the package.
So here’s my ultimate goal. I’d like to record statistical “usage” data with this counter. What I envision is when the PIR detects motion it will not only increment the counter (still necessary for a visual check) but also log a Time/Date stamp to an SD card. I could then pull the SD card out and plug it into the PC and get a .txt file from it which I can open in Excel. This text file should have a number of rows, each showing a unique time stamp of when the counter was triggered.
Please understand, this is a very ambitious goal for me because I’m very new at BASIC and I've really only written one or two practice programs.
Also, I’ve seen lots of hardware out there that “looks” like it would do the job but again, I don’t know enough about the hardware or how to program it to make any educated purchases.
Just doing a bit of hardware research I've come up with what looks like the right ingredients:
- Then a SD card interface or SD card data logger, like THIS or THIS
Hardware: am I even close? Again, I'm more or less guessing that these components would work. If someone has a different idea, please... do chime in.
As far as code goes... sheesh, I'm scared. Would it be totally rude of me to ask if someone could put something together for me? Once I can see it I'm sure I can make modifications.
If that's an inappropriate request I understand.
I still have the code I used when my plan was to run the PIR through an 08M (I can post that later since I'm not at home right now).
