mrburnette
Part 1
"the 18M2 port" continues in Part 2: http://www.picaxeforum.co.uk/entry.php?39-IR-set-18M2-clock-implemented-into-AXE133Y-OLED-display
My wife works in a doctor's office and was going to throw away two old "drug company" wall clocks because the batteries had leaked. Fortunately, she brought them home first. It was my good fortune to find that the works was as described by Jose Pino: http://www.josepino.com/?one_second_timebase and I am aware this has previously been discussed. I followed the recommended instructions and the circuit performs well with an 08M2; my only modification being the addition of a 4R7K resistor from the diode outputs to ground (reduces issues with hum tremendously... on the breadboard, getting my hands too close to the clock jumper caused the count to be erratic and the resistor terminates the signal and cleans up the pulse nicely.)
After I had a 1 second quartz source, I decided to move forward and build an elapse time digital clock from the 08M2. That was easy. Then, I got to thinking about a real time digital clock... in 24 hour format. The code was again easy.
Then it came the time to incorporate the physical buttons for setting the time. I searched my push-button switch drawer and found some nice momentary contact switches. For some reason, I just decided that adding switches to such a simple circuit was an overkill. Why not use an old TV remote control? I even have one on the work desk that is one of the universal kinds that I sometimes use for the little digital TV over in the corner of the work room.
I used this IR receiver:
http://www.goldmine-elec-products.com/prodinfo.asp?number=G16737
I searched the forum but did not find exactly anything that I could plagiarize, so I wrote it and decided to share. I intend on porting the entire code into an AXE133Y and dedicate the OLED display as a clock with temperature... in the next phase.
The code is more of a work in progress, but it does work. Since getting the formatting and such is somewhat of a pain, I thought someone else may wish to have access, too. The full PICAXE 08M2 program is included in the ZIP.
Let's talk a bit about the individual sections:
In the above snippet, ISset is "0" at power-up, so the clock is unset. After setting using a Sony-compatible remote, ISset will be 1.
You will notice that I use bunches of DispFlag settings with a GoSub Display... this is my way of keeping the display code and formatting to a bare minimum. Nothing is ever repeated exactly, so the code space required for LCD output formatting is minimized. Each DispFlag/GoSub represents something unique.
Nothing very exciting here. The repurposed quartz circuit, with diode modifications, produces a 50mS positive pulse of approximately 4.4 volts. The first PINC.3 statement holds the program until a positive pulse is seen from the timebase. The second PINC.3 statement holds the program until the pulse drops from high to low. After this, there is approximately 900mS to play around with display and formatting stuff and get back to the first PINC.3 wait.
The "Display" section should require no comments, it is very generic. Formatting commands come straight from the OLED reference documents. Change if required for other displays.
GetIR is simply brute-force code. The 3-wire IR receiver output is normally "high" when idle. I make no attempts to filter for multiple IR values that come from the remote if one holds a button too long... learn to press the button firmly and fast or write code to drop all but the first digit.
Using the PICAXE references, the subroutine CorrectVal changes the IR received value to a normalized digit, 0-9. Consult the table in the Rev Ed documentation on IR interfacing.
I will post the success (or failure) for incorporating this code directly into the OLED PICAXE 18M2 for the AXE133Y module. At present, I'm debating if I will remove the SERIN functionality or attempt some strange magic spell that will just toss up the time/date if no activity is on the SERIN receive pin after a timeout period. The top line of the display is a static "Current time:" phrase which I was going to replace with the temperature, but I may implement some kind of scrolling across the top for other inputs, too. Just thinking...
- Ray
More thoughts... higher number values, more recent chronology:
(1) In multiple PICAXE systems (quasi-network), it may be possible to dedicate a single 08M2 to perform the IR receive various inputs and alignment calibration. This would minimize overall cost by only having one IR receiver in the system.
(2) I wanted to use a simple 1-second, 50-60Hz, or other pulse train divided-down-to 1 second to keep the entire clock near the co$t of the AXE133Y... but it is going to be difficult (opinion) to add sufficient functionality to the code of the 18M2 serial PICAXE without having a RTC off-board doing clock-ish stuff. I also only have 3 spare 18M2 lines; 4 if I kill the serial input. The more I think about the features that users are requesting which would require IR to be processed while keeping-time up-to-date, the more I am thinking that IR may have to be off-loaded.
Initialize:
' Set frequency
setfreq CLOCK
' Set time - time is 24Hr mode
hour = 00
mins = 00
secs = 00
Top:
; Send startup message to serial port
DispFlag = 0 : Gosub Display
[B]If ISset = 0 Then[/B]
DispFlag = 1
Gosub Display
PAUSE 5000
Goto SetClock
Else
DispFlag = 4
GoSub Display
DispFlag = 5
GoSub Display
EndIf
Main:
[B]Do while PINC.3 = 0 : Loop[/B]
secs = secs + 1 // 60
If secs = 0 Then
mins = mins + 1 // 60
If mins = 0 Then
hour = hour + 1 // 24
EndIf
EndIf
[B]Do while PINC.3 = 1 : Loop[/B]
DispFlag = 2 : GoSub Display
Goto Main
Display:
Select Case DispFlag
Case 0
serout Serial,BAUD,(254,1) 'Clear
Pause 750
Case 1
; Line 1 Pos 1
serout Serial,BAUD,(254,128, "Clock not set...")
Case 2
serout Serial,BAUD,(254,192) ' Line 2 Pos 1
If hour = 0 then
serout Serial,BAUD,(" 00:")
elseif hour < 10 then
serout Serial,BAUD,(" 0",#hour,":")
serout Serial,BAUD,(" ",#hour,":")
endIf
If mins = 0 then
serout Serial,BAUD,("00:")
elseif mins < 10 then
serout Serial,BAUD,("0",#mins,":")
serout Serial,BAUD,(#mins,":")
endIf
If secs = 0 then
serout Serial,BAUD,("00")
elseif secs < 10 then
serout Serial,BAUD,("0", #secs)
serout Serial,BAUD,(#secs)
endIf
Case 3
; Line 1 Pos 1
serout Serial,BAUD,(254, 128, " Clock Setup ")
; Line 2 Pos 1
serout Serial,BAUD,(254, 192, " Use TV Remote ")
Case 4
; Line 1 Pos 1
serout Serial,BAUD,(254, 128, "Current time: ")
Case 5
; Line 2 Pos 1
serout Serial,BAUD,(254, 192, " ")
EndSelect
GetIR:
IRIN C.2, B9 ; X_:__:__
GoSub CorrectVal
hour = B9 * 10
DispFlag = 5 : GoSub Display
IRIN C.2, B9 ; _X:__:__
GoSub CorrectVal
hour = hour + B9
GoSub Display
IRIN C.2, B9 ; __:X_:__
GoSub CorrectVal
mins = B9 * 10
GoSub Display
IRIN C.2, B9 ; __:_X:__
GoSub CorrectVal
mins = mins + B9
GoSub Display
IRIN C.2, B9 ; __:__:X_
GoSub CorrectVal
secs = B9 * 10
GoSub Display
IRIN C.2, B9 ; __:__:_X
GoSub CorrectVal
secs = secs + B9
GoSub Display
ISset = 1
GoTo Top
CorrectVal:
If B9 < 9 then
INC B9
B9 = 0
EndIf
- Ray
