I have a Windows 7 PC that I am using as a "Media Centre", and to control it I have a Logitech Harmony handset that transmits the correct codes to a USB DVB-T receiver that has a built-in IR receiver. Unfortunately, when the PC is put into standby, the DVB device is not capable of bringing the PC back to life - only the mouse/keyboard will do that!
I could spend a few quid and buy an 'official' IR receiver that would probably do the job, but I have done a lot of research and it seems that even commercial devices have problems with waking up PCs.
What I am thinking of doing for a solution is to dig out an old USB mouse and modify it to accept a mouse-click from a picaxe-controlled IR receiver. I could then programme the receiver to accept a specific code to 'click' a mouse button for me, and this would bring the PC out of standby.
I have all the components I need lurking in the garage; USB mice, some spare picaxes, several varieties of IR sensors and miscellaneous components, but I just wanted to ask for a bit of input before I get started.
1) Is this a stupid idea?
2) Am I missing something obvious?
3) Is there an easier way to achieve the same result?
4) Any other thoughts?
The only thing that I am bit uncomfortable about is the actual 'mouse click' bit; how do I complete the circuit for the mouse button without frying the USB port? I do have a few old PCs/motherboards that I could use to test the circuit before connecting it to my expensive media PC!
Also, I am hoping that the USB port will be able to power the receiver. Does that sound right before I waste my time looking for a solution?
I am hoping that someone can point me to a suitable circuit as a starting point.
Comments appreciated.
Thanks.
Thanks.
