Some time ago I made a picaxe controlled incubator to hatch duck eggs. It works well. When I made it I attempted to use a light dimmer switch to control the light globes I was using as the heat source. I had problems getting the dimmer app to work as I wanted so I gave up at the time and went with a I/O relay set up. I like the dimmer control idea so the temp in the 'bator is more constant, a flat line on a graph rather than a square wave as the lamps turn on and off. I'm going to hatch goose eggs this year and they are a bit finicky compared to ducks and chooks.
I am going to use a IR remote controlled 240AC dimmer switch out of the UK I found on ebay. http://www.ebay.com.au/itm/160661625573?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_2732wt_1396
I propose to use picaxe Irout command to controll the switch. I'm hoping on the picaxe generated commands will be recognised by the receiver.....
My question is about the load handling capability of the switch. It is rated at 400 watts. Does this mean that I can only connect a 400watt load to it ot does it mean that is the max load to which it will provide full power?
ie. if I connected a 800watt load to it would it only run the load at half power, ie supply only 400 watts to it ?
I propose to use a electrical element with it out of a old oven or dryer. Here's a good article about hacking such elements.
http://www.thebackshed.com/windmill/articles/BuildingEncapsulatedResistors.asp
I can mod the element down to =<400 watt according to the article in anycase.
