I have just tried using interupts for the first time today on an 18A,
I have copied the code from the user manual exactly for the setint command, but when i try to download it to the chip a empty messagebox with the title "Compile Error..." comes up and the process fails, this doesn't happen without the set int command,
for reference my code is:
The project should wait until the input0 is pulled low and released (pull up resistor) and then wait for a serial command on the line.
Any help on this message would be good
jon
setint 0,0
start:
if b0 = 2 then ledtoggle
if b0 = 1 then ledon
if b0 = 0 then ledoff
goto start
ledtoggle:
toggle 0
pause 100
goto start
ledon:
high 0
goto start
ledoff:
low 0
goto start
interupt:
if pin0 = 0 then interupt
serin 0,n2400,b0
jon
