Professor601
Greetings, programs.
I am working on the next rev of my current Picaxe project, which is going to need to fit into a small space (1" {2.5 cm} diameter pipe). I wish to connect a smaller I/O board that will have a few LEDs and three sensors on it to the main PCB I will design that will hold a Picaxe, an Op Amp, and a few other odds and sods. The assembly idea I have right now will entail attaching the I/O board into the case, then conecting the main board using some sort of standard connector system before I slide it in and secure it to the case. Right now I expect I will need a minimum of 10 wires in the connection.
So, advice please: there are gazonkers of different kinds of connectors out there. What might members of this esteemed fourm suggest I look for? I expect it will need to be wired rather than a M/F header connection, but any thoughts on how to narrow down my search? I'm a tad overwhelmed by what Mouser has to offer.
Courteously,
The Professor (601)
Courteously,
The Professor (601)
