Alex Leech
Hi all!
Im sure many of you have seen the instructable:
http://www.instructables.com/id/Control-real-world-devices-with-your-PC/
Ok so it uses the use of the serin and serout commands and i have it all working fine ... But can someone explain to me if its possible to use the serrxd and sertxd commands as this would be so much easier from a hardware point of view!
I have tried changing them over and also changing the VB net baud rate to suit but it doesn't register ...
Any suggestions?
A working program or explanation would be much appreciated!
I'm using a picaxe 28X1 as a 08M wont support Serrxd
Cheers!
Leechy
Any suggestions?
Cheers!
Leechy
