Tricky Dicky
When an Infrain command is executed in a program does it prevent any other inputs or interrupts. I cannot find anything documented in the manuals but that seems to be the case in any programmes I have tried. I know that when the programme reaches an Infrain command the flow is halted until an appropriate IR signal is received after which it will continue to execute the programme. However, from the tests I have run it simply ignores other inputs or interrupts even after the programme continues.
Richard
Richard
