In Flowchart mode:
I enter the following:
Start <-<-<-<-<-<-+
if pin0=1 Y----+ ^
N-------------V--+
stop
The code I see produced is:
label_14: if pin0=1 then label_19
goto label_14
stop
as you can see, label_19 is not inserted before the stop with the result that it fails a syntax check when you try to download.
Is this a known bug? It seems to be new for version 5.0.7
Is there a workround? It is causing great headaches trying to use existing teaching materials.
Start <-<-<-<-<-<-+
if pin0=1 Y----+ ^
N-------------V--+
stop
goto label_14
stop
