Folks - Has anyone had any bother with the If statement on the 14m firmware version 9C?
Code is as follows:
serin 1,N4800,("ABC"),b1
if b1 != 1 then goto Turnonandoff
Turnonandoff:
Toggle 5
With b1 I have used both not equal to 1 (!=) and equal to 1 (=) on the simulator and it works as expected.
When I download either program to the 14M they work opposite to what they should.
Ie. When using the Terminal program with the above code, when sending ABC1, it runs through the whole program and toggles the output - and it shouldn't. As it does with ABC2,ABC3 etc.
If however I change it to if b1 = 1 then goto..... absolutely nothing happens. ABC1 wont even toggle the output. Nor will anything else.
What am I missing here.
I am having a Blonde moment.
Any help appreciated
Hooter
Code is as follows:
Turnonandoff:
Toggle 5
Hooter
