Roboteernat
Is it possible somehow to...
make an if or statement where the variable its comparing to is plus 10 or negative 10, ie
<code><pre><font size=2 face='Courier'>if b1 <= (b12 - 10) or b1 >= (b12 +10) then ... </font></pre></code>
the command goes to ... if the value for b1, say 100 falls not between b12, say 200, does not fall between 190 and 210.
or would i need to use 2 registers to save the b12 - 10 and b12 +10 values.
thanks for any help
nat poate
as i need to use all the other registers and only have b12 left.
thanks for any help
nat poate
