Hi all, wondering if you could give me your advice. I found this circuit on an atmega forum, tweaked it a bit but was wondering if this would work using an 18M2. I'm trying to pwm control multiple 12v led strips (each rated at typ. 90ma) using the limited 2 pwms channels on the PICAXE. Code would be pretty straight fwd looking at the circuit, set pwm output for b.3, set corresponding transistor output high for whatever LED you want to light? Any comments, concerns would be appreciated. Thanks!
