I've read up on using the i2c bus and I think I understand it pretty well. I want to use one master PICAXE to talk to several slaves which will gather data (and make it available to the master via scratchpad) and also control outputs (by using data sent from the master).
My main question is regarding the physical limits of i2c. The PICAXE's would be in separate enclosures with distances of perhaps 10 feet maximum (some are closer). Can I use the i2c bus over such a distance? Anything I should worry about or precautions to take?
Or do I need to consider a different method of communicating altogether?
