Has anyone played around with ganging lots of i2c devices together on a "bus"?
Looking to get LOTS of IO (64) with PC8574 port expanders and wonder how far the bus will run before i get probs?
Concept is a series of DIN rail modules with combinations of I/O ganged together to "master" module. Is it possible to use bi-di drivers on the lines to improve reliability/distance (if its even a problem?)
I estimate max length of tracks from PICAXE would be 8 modules of 60-80mm length (ie 500-700mm approx) - is that feasible?
I know I can get other port expanders with more I/O than 8 - thats just more convenient for the concept at hand (which happens to interface to something else that works with multiples of 8 I/O!)
Cheers
Stocky
Cheers
Stocky
